Dear all, I want to show dual dimension where Inch is my primary and mm is as secondary dimension. My problem is I don't know how to show " after inch dimension i.e. 12". I am able to show only 12. Your reply will be appreciated. Regards, Vimlesh Patelia (India) This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Right click on drawing, select drawing options, then in options box, type dual_dimensioning, select Primary(secondary) and click on add/change. Scroll down to dual-secondary_units, select mm for the value, then add/change. Maria
To get the inch marks on your base dimension, double click the dimension and select the "Dimension Text" tab. Hand enter the " after the diension text you see.
Maria, I think that is to show dual dimension not to show ". Chris, At that time I have to do for all the dimensions. I wanted to make change in config so for any drawing and for any number of dimensions I could get at a time. Thank for suggestion. Regards, Vimlesh
