Problem in Showing Dual Dimension
ptc-1972305
Dear all, I want to show dual dimension where Inch is my primary and mm is as secondary dimension. My problem is I don't know how to show " after inch dimension i.e. 12". I am able to show only 12. Your reply will be appreciated. Regards, Vimlesh Patelia (India)
Right click on drawing, select drawing options, then in options box, type dual_dimensioning, select Primary(secondary) and click on add/change. Scroll down to dual-secondary_units, select mm for the value, then add/change. Maria
CBenner
(To:ptc-1181136)
To get the inch marks on your base dimension, double click the dimension and select the "Dimension Text" tab. Hand enter the " after the diension text you see.
Chris Benner
Autodesk ® Expert Elite
Maria, I think that is to show dual dimension not to show ". Chris, At that time I have to do for all the dimensions. I wanted to make change in config so for any drawing and for any number of dimensions I could get at a time. Thank for suggestion. Regards, Vimlesh
