Gurus,
I'm having a problem with overlays. When I create an overlay of a
view that has a detail callout in it the spline around the detail area
moves. They movement is random. I can create several overlays of the same
view and in each one the detail spline is in a diferent location. When the
overlay is moved the spline moves with the view. The same thing happens with
a CG symbol but not as consistently. It moves overlays from one drawing but
not another. I'm using iLink 3.3, m020 and Proe W1 M150.
David W. Lawrence
BAE SYSTEMS
Mechanical Systems Integration/COA
Voice (301) 231-2924
Fax (301) 231-3397
