Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I'm working out side of windchill in a working directory and would like to purge the extra files in my working directory, in which I have several drawings, assemblies and parts. I say that because backup I don't think would work very well. I tried delete old versions when I have a part open. That is what I want to do, but for the whole folder. I've got 200-400 items in a folder, and I have a couple of folders to purge. It seems as though there used to be a purge command in later versions. What do others do to accomplish this? TIA
Eric Fleming | Engineering Technician ITT Corporation, Residential & Commercial Water, 1 Goulds Dr., Auburn, NY 13021 Phone: 315-258-4840 | Fax: 315-258-4809 | -<">mailto:->
Hi Eric The purge command is still there. I'm on Wildfire 4 M100 (installed clean yesterday) Open a command prompt (DOS) window goto your working folder and type in purge. Regards
Sarah Ford CAD Designer Tel. 01202 627200 Ext. 236 www.westwind-airbearings.com
