Restricting a Pro/E parameter to only certain values
mganzer
Hi All,
I know I have seen this before, but I cannot find it. isn't there a file that can be created that will restrict Pro/E parameters so that they can take on only listed values? For example you could set a Pro/Eparameter called INTEGER_COUNT so that it could only be set to 1, 2, 3 or 4.
Mark
8 REPLIES 8
cschmid
(To:mganzer)
I would also like to understand how to do this.  Let me know if you find more information.
BenLoosli
(To:cschmid)
Restricted_param.txt file
config.pro setting is: restricted_val_definition <drive:\folder>\restricted_param.txt
File format:
ND_ParamDefArr_K01 = {
{Name=Integer
Type=string
Default='1'
Enum={'1','2','3','4','5','6'}
See https://www.ptc.com/en/support/article?n=CS51011
TomU
(To:cschmid)
In Creo Parametric 4.0 and later it is possible to create these parameter restrictions interactively.  See video.
(Note:  Video will not be viewable until the moderators approve it.)
Patriot_1776
(To:TomU)
Bummer it's not available in Creo 3...
TomU
(To:Patriot_1776)
Yeah, only in 4.0 or later.  Here is the related KB article:  https://www.ptc.com/en/support/article?n=CS297223
Patriot_1776
(To:TomU)
Cool, thanks Tom!
Only the interactive adding of restricted parameters without a restricted_params.dat file is new in Creo4.
You have been able to create restricted params by loading a file since Wildfire2.
Patriot_1776
(To:BenLoosli)
That's what I mean.  It's absurd that you'd have to write code, then add a config.pro option to find your code.  what is this, the '80's?  I never had to play with it before, and now it would be useful to me, so hopefully we'll get on Creo 4 before I really have to mess with it.
