Rulestream
ClaudiuCraciun
6-Contributor
Rulestream
Hi, I'm looking for an automation program that can work with ProE. What we expect from this program is to follow some rutines already established: - modify dimensions - supress\resume layers - supress\resume features, components - assemble\replace components - update CAM files - export proe files under different format to be able to be connected to a data base (sql) from where to extract information that required to be updated in proengineer parts Is it Rulestream what we are looking for or there is other application that can do the abouve request CC
By the way I found that in October Rulestream was purchesed by Siemens. Any Ideea if there will be any future for Rulestream integrated under Proe if Siemens works with UGS.
