STL from STEP
davidbyrne
STL from STEP
One of my users got two files in STEP format from a mold shop to convert
to STLs for rapid prototype production. He brought one into Pro and saved
a copy as STL with no problem, but the second file did not give him the
STL option when in the "Save a Copy" dialogue box. Does anyone have any
idea as to why? Thanks.
Dave
The second file is likely not a solid. Please refer to the Knowledge Base article:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=103697
If this is the case, repair the imported geometry to make it solid and then you can export it as STL.
