Showing harness length in drawing note
ptc-4664277
Newbie
I had a user ask me how to show the harness length in a drawing note. The length can be shown in a table using harn.run.len. Does anyone know where the table gets the data, and/or how I would show that in a note instead of the table?
Matt,
To add this report parameter to a table in WF 2.0, make sure your table
has a repeat region, then:
-Left Click the Cell you want to add the Report Parameter
-Right Click to select Report Parameter
-Select harn
-Select run
-Select len
-This creates the Report Parameter called harn.run.len
-Update your table and you will see your cable/wire lengths
For the second part of your question, I tried creating a note having
&harn.run.len parameter, but it does not do anything. If you discover
how to make this work, let me know as I would be interested.
Re: Showing harness length in drawing note
New relation in drawing, look in - part
such as,      aaa=cable_len("w-1",location id 1,location id 2)
                       bbb=cable_len("w-1",-1,-1)
then add &aaa or &bbb
more info about function cable_len, refer to article:
https://www.ptc.com/en/support/article?n=CS111494
Cabling Mode Function
