All,
I've created a drawing that has two views - one of the master rep and
one of the simplified rep. I have dimensions shown on both views. On
the master rep view, if I change a dimension display from @D to @S and
save the drawing, the model is also saved. However, if I do the same
thing on the simplified rep view, the model is not saved.
What gives?
Tyler (WF3)
P.s. We have the following potentially-related configs set (and I can't
change them on a global level - maybe they can be changed for this
particular drawing only?)
Save_modified_draw_models_only yes
Save_objects changed_and_specified
