Slot Center Lines
hspaulding
Slot Center Lines
I have created slots in a sheetmetal part. I then added a centerline (axis point) to the center of the slots. When I get to the drawing phase, the formed view shows the center line correctly but the flat state shows the center line in correctly. (see attached pdf) How can I make the center lines show up correctly in the flat state?
Hello Herb, Use the same references as the centre lines for the slots. Mike
