We are working in large assemblies that contain about 2000 different parts. Some parts are fasteners that are used many times so total parts displayed may be several times that. I open the assembly in graphics rep mode along with simplified reps, we are running pipes and cables. If I run a search on a file name to make master to work on, the search window takes from 1 to 10 minutes just to pop up, then another 1 to 5 minutes to find the file name. Average time to use the binocular and find a model is 5-8 minutes. That seems to be a lot of waiting for a 3ghz 64 bit machine with 8 gig RAM and only 3 gig RAM in use just to find a component? I can open an empty rep and search for a model to change display and it does the same thing.
It does the same results on other machines so it is not my hardware.
Has anyone else seen this issue?
WF3 M200
HP9400 Box XP
Gerald Lanz
Teledyne Brown Engineering
Ares-1 Upper Stage MPS- Design Engineer
NASA/ MSFC/ ER34
Bldg 4708-Room 1103
Office: 256-544-0861
