Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
We had a similar problem, are you checking the 'visible only' button on the PDF export setting dialogue box? We don't get problems here as long as we check that visible only button...
Regards
Jon Tribe
"Roy, Jean-Frederic" <->
02/06/2009 02:06 PM
Please respond to "Roy, Jean-Frederic" <->
To
cc
Subject
[proecad] - Curved Edges: PDF Print vs PDF Convert
Hi all, WF3.0 I'm trying to figure out why the ProE-imbedded PDF converter doesn't show curved edges correctly while printing in PDF doesn't cause an issue with the same part (see attached PDF files). I played around with the hidden lines and the quality of the pdf and it doesn't seem to affect anything. I also changed the pen-line weight without success. Any ideas? Thanks, Jean-Frederic Roy, M.Eng Sr. Mechanical Designer SPIELO, A GTECH Company tel: 506.862.1460 fax: 506.852.7640 - <">mailto:-> www.gtech.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
