Solution: Deleting a quilt from an import feature
dgschaefer
This was the answer (original Q below):
Do you have a copy of WF4? If so you can use the import data
doctor. If you select one surface you can then see where it is in the
model tree and select all of the surfaces near it. After you are done,
you can export and re-import into WF3
It worked great. You need to select the import feature, select edit
definition, then click the 'import data doctor' button (look for the red
cross). All the items in the import appear in the model tree. I was
able to select the entire quilt and hit 'delete'. Done.
Another suggestion was to do the same but use Solidworks as the
intermediary. No solutions just using WF3.
Doug Schaefer
LinkedIn
0 REPLIES 0
