Tolerance Display and Instance Display
NEALROSENBLUM
1-Newbie
All,
Is there a config.pro option to turn off the X.X, X.XX, X.XXX, ANGLE, and INSTANCE display in part and/or assembly mode? I want to print out some simple JPEG's and this information gets in the way. I prefer not to use Photorender because I do not have the patience to start dealing with backgrounds, lighting, etc.
TIA,
Neal
2 REPLIES 2
Here is a quick way of dealing with it without a config option:
VIEW
SHADE
This will eliminate the screen text and DTMs.
you will need to REPAINT to allow more than one item to show as selected.
REPAINTing exits VIEW, SHADE mode.
Tip#1
Make a mapkey to export your image that does the view, shade, then save
as.
Tip#2
VIEW, SHADE also allows large assemblies to spin freely.
?Why does VIEW,SHADE allow the models to spin better than just shade? PTC
was unwilling to explain.
But it works great!!
Jason W. Livengood Sr.
Varian Semiconductor Equipment Associates
35 Dory Road
Gloucester, MA 01930
Tel 978-282-2758
Fax 509-757-7148
VSEA Confidential Information -
The information contained in this document is VSEA Confidential
Information and is disclosed in confidence.  It is the property of VSEA
and shall not be used, disclosed to others or reproduced without the
express written consent of VSEA.  If consent is given for reproduction in
whole or in part, this notice and the notice set forth on each page of
this document shall appear in any such reproduction in whole or in part.
The information contained in this document may also be controlled by the
U.S. export control laws.  Unauthorized export or re-export is prohibited.
"Neal Rosenblum" <->
07/05/2007 09:01 AM
Please respond to
To
cc
Subject
[proecad] - Tolerance Display and Instance Display
All,
TIA,
Neal
WF 4
Please remind me of the Tol setting in the config file so I can change the type and values.
TIa
