Trouble Opening a Neutral File
ptc-2980910
I downloaded a bearing assembly from a vendor that was saved as a neutral file. How do I open a neutral file. I have tried opening it the same way I would a normal part or assembly file but I get the error: "File name can not be retrieved" I have attached the file that I downloaded. Can anyone help me with this? Thank you for your time.
Oops...sorry I attached the wrong file. Here is the correct one below.
Opened fine here. Had to tell it to view all files the just selected the first file (inafag60_bora4eoz78q2c3wqi5r.neu.1). It opened as an assembly. I couldn't attach the bearing assy as pro-e WF4 increased the size (after zipping) to greater then 1.2 meg, which apparently exceeds the allowed size of attachments.
Dear Friend I open it with ease. I use wf 4 M80 what is your pro/e wf4?
ptc-876037
(To:dtran)
The only thing I can think of is, did you during installation click on to install all sub features to "Pro-Interface"?
