Using ProE 2.0 - Solid model for Assembly Drawing
ptc-1789647
Is it possible to change the appearance of the drawings from outline form to solid colors, as in each component of the assembly has its own color is filled in (similar to the way it looks in part modeling mode)? Thanks for the help!
7 REPLIES 7
Change your display type for the view to solid; that will give the model colors.
The only options it gives me for the view properties under the View Display (display style) is Default, wireframe, hidden and no hidden. Not sure if this is what were referring to.
That might be due to your old Wildfire, thinking back several years WF3 had solids as a new view feature.
There is a config.pro option "enable_shaded_view_in_drawings yes", but I don't know if it applies to Wilfire 2.0.
Thanks all. I think you guys are right. Not available in 2.0. Guess I'm going to have to tell management to upgrade.
