How is everyone using the finished engineering model with ProMan? Our manufacturing guys do not use theengineering model with ProMan, they are creating separate models based off the finished part print for each machining operation (because grind stock etc. needs to be added) which leaves a complete disconnect between the engineering model and the manufacturing model.
Are you using Inheritance Features? Merged models with added grind stock? ProProcess?
Any comments are welcome, we are waisting time!
