Using same parts in assems
RandyGentry
I have a lot of parts in my assems that are used more that once. For example a bushing on the left also gets used on the right. Now when I try and add them to my assem(the same part through the assemble command) they totally mess up my other parts that are the same. Like the original part constraints go all batty. But if I click the rebuild button about 5 times they will eventually start to work. Any ideas why it is doing this.
NV mind i figured it out. Seems that when I try to constrain my parts to geometry it tweaks. But if I do it to datums like the original file it works fine.
