Has anyone observed a bug where a global interference check ignores your simplified representative setting?
Here is what happens - if I open an assembly simp rep (without other parts in session), the global interf check works as it should. But if I switch to the master rep (thus putting all parts in session) and then switch back to the simplified rep, the global interf mistakenly checks for interference between all parts, even those that are excluded from the current simp rep.
Thanks, Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Quick follow up - I opened a call and PTC could re-create the bug they did not have a fix. Hopefully they'll fix it in the future. I've also seen this issue is numerous assemblies. Perhaps the problem is caused by assembled parts (or start parts) created in earlier versions of PROE.
