Hi Jonathan,
We made the jump from WF2 to WF4 and had similar concerns.
Never found a way to solve a), did not think of b) and did not solve c) either.
But I continued with the Favourites Tab and I put all the project folders I want in there (renaming them if necessary to distinguish between them). I can get to this by clicking on the Favourites Tab or clicking favourites in the Common Folders. The big deal with WF4 is that you can now RMB and set one of these to your working directory!!!!!! (OK so I was very pleased to get this functionality)
In conjunction with this I have mapkeys for OP = open part, OA = open assembly, OD = Open drawing and these call up the older style file dialogue box (which is still available if you use File/Open rather than the tree.)
I have found over time that I use a mixture of both the newer and older method to navigate and get what I want so I suggest you go with the change. In effect PTC did move the cheese but they gave extra functionality to what already existed.
Hope this helps.
Regards, Brent Drysdale
Mechanical Designer
Tait Electronics Ltd (www.taitworld.com)
New Zealand
Ph. +64 3 358 1093
Hodgson, Jonathan P wrote:Good afternoon gurus,
We've just made the jump from WF3 to WF4. There are a couple of things
we like, but so far the Common Folders pane (both in the main window,
and in the new - very cluttered-looking - File Open dialogue) is not one
of them.
Is there any way to:
a) turn off display of Common Folders;
b) if not a), remove any of the default entries;
c) make the Folder Tree expanded by default?
It also appears that WF4 doesn't place its menus anything like as
helpfully as WF3 when you have dual monitors, but I suspect we will just
have to live with that one...
Jonathan
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient). Only Directors are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and other telecommunications systems.
By replying to this e-mail you give consent to such monitoring. The recipient should check e-mail and any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail. "Ricardo" means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
