WF5 Drawing environment has gone to 'ribbon' menus as seen in MS Office 2007 - this means an extra mouse click to enter the appropriate ribbon and then select the desired tool. Also for infrequently used tools there is that process of searching through the tabs.
The MS Office system works because it has a quick access toolbar which you can position below the ribbon menus and load with your popular tools - can't find anything like this with the new ProE menus (?)
Tried creating a custom toolbar but the tool icons containedin the ribbon menus don't seem to be available in the Commands tab. Spose I could create mapkeys and assign icons and then apply to a custom toolbar - messy though.
Any suggestions/thoughts?
Cheers, Sean
