Welding problems
BrianPassafiume
1-Newbie
Welding problems
I have an assembly of tubes have angled notches that are to be welded together but I am having trouble. Does anyone have suggestions?
3 REPLIES 3
Brian I think you need to provide more detail on the issue you are having trouble with. Are you trying to use the weld feature? Or are you trying to model the notch correctly? Eric
I am making an aluminum space frame that is an assembly of notched tubes. After assembling these tubes I want to use the seld feature.
I mean "weld"
