The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
drawing rep
ptc-111338
1-Newbie
drawing rep
Hello All,
I am trying to use Drawing Representation menu in order to show 3 different states of a flange in a Proe Drawing. (power point presentation attached)
The main issue is that the flange goes around with a circular edge and the base of the flange is 4° angled, so it is not possible to unbend the feature with the regular operations of sheetmetal (because of this 4°).
Do you know more options to have this views represented in a drawing (keeping one single 3D parametric model).
Thanks for your comments.
Best Regards.
[cid:image001.png@01CA2FB7.5F9C4D40]
Best Regards.
[cid:image002.jpg@01CA2FB7.5F9C4D40]
hugo miranda
cad/cam/cae leader
acceso b, no. 406
parque industrial jurica
zip. 76100
querétaro, qro. méxico
ph: +52 (442) 211 4927
fax: +52 (442) 211 4888
dialcomm 8*553 4927
e-mail: -
This communication may contain confidential information intended only for the person to whom it is addressed.
Any views or options expressed are solely those of the author and do not necessarily represent those of mabe or general electric
consumer and industrial (GEC&I).
Any use, dissemination, forwarding, printing, or copying of this e-mail without consent of the originator is strictly prohibited.
If you have received this e-mail in error, please immediately notify the author by telephone at 52 (442) 2114927
1 REPLY 1
I would use a perimeter dimension so you can vary the bend angle while keeping the length of the "inside" surface fixed.
I think I would also convert the whole length into a spline, to be able to make the bend flatten out as shown in the "unbent" state.
The varied parameters could be controlled by a family table.
You would have to add all 3 instances of the family table to the drawing.
