The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
The first thing to check isthat your config.pro file contains the following line
graphics opengl.
It would be worth checking that yourQuadro graphics card dirvers are configured correctly for Pro/E
>Go into Windows display properties
>Select the settings tab
>Select advanced
>Select the Quadro tab for your graphics card
>Open the nVidia control panel
>On the left under 3D Settings, select Manage 3D Settings
>On the Global settings tab, from the drop down menu select Pro/Engineer
