I have a slightly cumbersome method to get this maximum distance. Create a second datum plane above the curve parallel to the first, then create an analysis to measure the minimum distance from the curve to that plane. You can then create a relation to subtract that distance from the planes' offset, giving you the maximum distance from the top of the curve to the original datum plane.
Good luck,
Dan M.
