mass of a wire
ptc-2046907
mass of a wire
Im trying to find mass of a wire/cable in pro/engineer wildfire2 using procabling,what i have done is just routed a wire of 1000mm length and trying to figure out the linear density of the wire,as linear density is mass/length im unable to get the correct density as it dosent match the specifications of the wire standard,so am i looking the wire mass in wrong way so can somebody help me how to find the mass of a wire.
You can specify the density (weight/length) value as a column in the wire spool. The system can then use this value and the length of the wire to compute the mass.
