Guru's,
What is the deal with the rotational degrees of freedom? WHEN do they
matter and when don't they? Seems like there are times when it doesn't
matter what I do with them, that the results are the same. For instance
if I fix a surface in x,y and z, and set it free to ROTATE about x, y
and z it's the same results as if I fix all 6 degrees of freedom...???
Is there some "rule of thumb" for this?
thanks in advance...
Paul Korenkiewicz
FEV , Inc.
4554 Glenmeade
Auburn Hills, MI, 48326-1766
