John, When you export your assembly as a shrinkwrap in the first place, why don't you use the "Merge Solid" option instead of the surface option? That way your exported model will be a single Pro/E solid part comprising the geometry of all components of your assembly. From the assembly, File >> Save A Copy and choose "shinkwrap" as the type.
