working on Stl files
gbon
I have to work on scanned points cloud.
So, I import point cloud in Wildfire 3 and then I can use it for designing my mechanical parts.
I'm working on human prothesis.
But, when cad work is done, I have to modify my scanned datas (stl file) in order to manufacture them (principaly adding some holes and cuts).
ProE don't let me doing anything on the Stl file.
I can make a Shrinkwrap file but its quality is to poor for manufacturing, even in best level.
So my idea was to make some volumes that I have to cut or add.
Then make Stl file from thoses volumes.
Then I'm expecting to use an other software for
- import my points cloud
- import the volume I have to add
- merge those Stl files
- import the volume I have to cut
- substract this volume of my points cloud
So, I'm wondering if this seems to be possible and then what software could I use for merging and substract volumes.
GB
Gary,
Without using a translation software, you cannot convert the mesh (*.stl)
file into a surface. I have had some success converting STL files in
SolidWorks to a surface or solid using the ScanTo3D add-in (module).
However, the STL files become "heavy" with tessellated geometry which
requires time and effort to edit the files using SW ScanTo3D add-in.
I have heard that Pro-E has a reverse-engineering module, but I have not
personally used it. There are probably some Pro-E users that could give you
an opinion on their experience using the REXX
Gary,
We have used the REX module successfully and my co-worker Steve Norgrove and I presented on its use at the International conference in Dallas a few years ago. Search under either of our names and you will find the presentation.
The tools in REX work well and generating a solid model from scan data is easily done
Mike Brattoli
