Hi everybody,
Does sb. have experience with WF-5 and Ansys Workbench?
Does the ProE-plug-In of Ansys work good. Where are the restrictions?
MF
ProE plugin worked good on my PC, i haven´t seen anything bad. But personally i compared results of mechanic analysis for one project in ANSYS Workbench and Pro/MECHANICA and it´s more fast and same values in Pro/MECHANICA.
Have you used the ProE PlugIn with Wildfire 5 as well?
Yes i don´t have problem with it, as i do
