Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Basically I asked, because I thought that any static analysis includes the weight of the own model, but it was not giving me what I was specking, so Gravity was an issue for my problem, now including gravity as a force, it is Ok.. it is solved. Thanks.
