MENU
Start a topic
Search
LogIn
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
All community
This category
This board
Knowledge
Users
Turn on suggestions
Close X
Community Tip
- Need help navigating or using the PTC Community?
Contact the community team.
X
Community
Creo (Previous to May 2018)
Creo Modeling Questions
INSERT/G5 P10000
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
INSERT/G5 P10000
GeorgiosLaboura
1-Newbie
Sep 08, 2011
01:51 PM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Notify Moderator
Sep 08, 2011
01:51 PM
INSERT/G5 P10000
Dear Pro/mfg Gurus,
In the customize tab I am inserting manually the following command.
INSERT/G5 P10000
The selected option in cl command is Current.
In the customize tab the additional command appears as following:
Tags:
creo_machining_proengineer_cam
ptcuser_portal
All forum topics
Previous Topic
Next Topic
1 REPLY
1
GeorgiosLaboura
1-Newbie
(To:GeorgiosLaboura)
Sep 08, 2011
02:37 PM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Notify Moderator
Sep 08, 2011
02:37 PM
Thank you guys for your help,
The format that worked is, INSERT/G5 P1000$
( $ at the end )
Thank you all.
Georgios L.
Post Reply
Business Continuity with Creo: Learn more about it
here
