Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I want to add my retract value to the begining of my sub routines. I am using "G98" and want the sub to set to the retract value before it starts the cycle. I have tried hard coding it and it works but I want to automate it so when I drill angle holes it will go to the correct retract.
