udf fails -can not find group
ptc-676778
1-Newbie
(Please ignore if you've already read on user post...sorry for double post. Wasn't sure where was best)
I have set pro_group_dir ilcs://prointralink/Root Folder/UDF Library When I try to open the group from that directory on commonspace, I get the message, "can not find group", however, when I open the group from the workspace, it is fine. After a failed drill/tap group, I created a new UDF with just one standalone holemaking sequence and had the same problem. Both udf's work from my workspace, but not from commonspace.??? Any ideas? TIA Jeff
0 REPLIES 0
