Callouts annotation weight Creo Illustrate
jlapointe
What is present: callout leader line weight is changable in interface.
Idea:  It would be desirable to do the same with the callout label so the border of geometrical form (circle, square...) matches the weight of the leader line.
It would also be desirable to add the possibility to change XML code by adding a property such as weight="Xpt" in shape code as shown in the following code
XML code:
<annotation id="partno" hasLeaders="true">
     <name locid="Part Number" />
     <description locid="Part Number Callout Style" />
     <tooltip locid="Part Number Callout" />
     <thumbnail url="partno_callout_img.png" />
     <leaders>
          <line-style weight="1pt" color="#000000" halo="false" dashes="Solid" start="none" />
     </leaders>
     <label canEdit="false">
          <text font="Arial" size="10pt" color="#000000">
               <useproperty category="System" name="pvITM" />
          </text>
          <shape type="circle" weight="Xpt"/>
     </label>
</annotation>
0 REPLIES 0
