Creo 2 installer - language selection only once
Hans-Dieter
Currently you have to select the languages you want to install for each Creo app separately. This is annoying because I want to have the same languages for each app anyway. If a special language does not exist for an app then just skip it but don't let me select the same languages 5 times over. This not following the Creo paradigm of having less mouse clicks
0 REPLIES 0
