Hi everyone
I have an issue with the distance tool in Creo View Express.
If i open an DRW file (created in Creo 7.0.2.0) in Creo View Express, and use the distance tool for measure something, the measure result is incorrect like a wrong scale.
But the scale of the DRW is 1:1 and in Creo View Express are 1:1.
I noticed that the error of the measure follow the dimension of the sheet in the DRW file (see the attacment).
But if i export the DRW file in DWG file, and i open the DWG file in Creo View Express the measure are ok.
Some one can help me?
thank you
