How to select only top level components with cursor in a Creo View model?
  • September 3, 2024
  • 2 replies
  • 1289 views
Is there any way to have a cursor select setting that only selects top level components in the structure in Creo View MCAD (aside from the top level assembly)?
Any type of solution to this will do.
(Creo View MCAD version 11 being used).
Catalina
Community Moderator
September 6, 2024
Hi @JosephTC,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Moderator
Hi Joseph,
With the standard filter (smart) you can select a part of your assembly
Then you could press the "left arrow key" many times you need until you arrive to the related "top level components" assembly.
7-Bedrock
February 17, 2025
@Trebla
The auto-jump to parts in my model tree when I select stuff is the first thing I disabled, as it's annoying and messing up my collapsed model tree view.
So using left arrow key wouldn't work in that case.
@JosephTC
You can also use the "Select Related" feature.
It can be pinned next to the model tree as well.
Select RelatedSelect Related
@Catalina
But it still is a nuisance to click so many times in Creo.
When you're shifting/puzzling in a layout a lot, it gets annoying.
In Inventor, you can just set a filter to either select lowest level (part) or top level (assy) in the current layout.
Would be nice to a have similar filter option in Creo, as @JosephTC suggested with his screenshot.
Update: My above comments are based on Creo. Just noticed initial topic was about Creo View.
