Hi, in the what's new for Creo View Adapter 10.1, it is stated that:
however, in our current testing, Assembly/flexible features seem to work well, but for virtual embedded components this does not seem to be changed or any better than previous versions. It says that there is no extra config needed, so I'm wondering if there is a certain Windchill version that is also needed?
currently running 12.0.2.21 and Creo View adaptors 10.1 - maybe 13.0.1 is needed?
Hi @RME_DH
For Virtual Embedded Component, it needed a fix from Windchill side, which is available from Windchill 13.0.2 release onwards. For more details reach out to PTC Technical Support.
Thank You,
Varad
Hi @RME_DH,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
Hi @RME_DH
Thank You,
Varad
Thankyou Varad, that explains it. we will test again when slated upgrade to 13.0.2 is on the cards.
