Hello forum, I have setup Modelcheck with assembly checks and interchancge-assy checks. The correct checks are being found by the models. I can see that in the results-window But: I have set PACK_COMPONENTS to Warning but no warning appears when a component is assembled without constraints. I have set PARAMCHECK to Error in .mch and ASM_PARAMETER REMARK STR in .mcs but when I check an Interchange-assy no missing parameter is mentioned. We work with Wildfire2 M250. We use Modelcheck interactive. Any ideas? Regards Gerald
