Converting 2 pt spline to line in sketcher.
ptc-1100844
Hi Pros,
I have many splines in a sketch between two points. (The sketch is
created from dxf/dwg).
Is there a way to convert a spline between two points to a line?
The intention is to simplify the sketch which has got lots of
dimensions, 0 distance between the two end points. I would be able to
create a hor/vert contraint when it becomes line, thus getting rid of 0
dimensions.
thanks
devendra
Warning: Copyright ResMed. Where the contents of this email and/or attachment includes materials prepared by ResMed, the use of those
materials is subject exclusively to the conditions of engagement between ResMed and the intended recipient.
This communication is confidential and may contain legally privileged information.
By the use of email over the Internet or other communication systems, ResMed is not waiving either confidentiality of, or legal
privilege in,the content of the email and of any attachments.
If the recipient of this message is not the intended addressee, please call ResMed immediately on +61 2 8884 1000 Sydney, Australia.
You probably need to change your import option so that you import those
lines as lines or curves and not as splines...
(In WF2)
Draw your new line/curve
Edit -> Replace
Select new entity
Select old entity. Probably it will ask you about deleting old
dimensions.
You can delete your old entity now.
Kind regards,
Murat
"Rane, Surendra
(GE Indust,
ConsInd, To
consultant)" Devendra Verma
<surendra.rane@ge <-=">,
.com> -
cc
15.10.2008 08:03
Subject
[proecad] - RE: Converting 2 pt
Please respond to spline to line in sketcher.
"Rane, Surendra
(GE Indust,
ConsInd,
consultant)"
<surendra.rane@ge <br="/> .com>
