Licensing Issue
PaulMailloux
Licensing Issue
Hello all
I am in the process of reinstalling ProE and Flexnet on a laptop which
needed a replacement hard drive and hence full re-installation of
everything.
Now I am having troubles with the installation of the license
management.
Here is my error message from the log file:
Displaying status for license file: 7788@nmc0029
License Server: nmc0029
Warning (-97): The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Feature: 127
Vendor:Host: nmc0029
License path: 7788@nmc0029
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
License In Use Free
Mechanism_Design* Counted
PROE_FoundationAdv Counted
I easily installed the original licensing without error but now, after
the full reinstall of the OS etc, I can't seem to get this to work.
I found out later that the user attempted to install UG which also uses
Flex so I uninstalled all PTC and UG products and started fresh, but to
no avail.
Any assistance would be greatly appreciated
Paul
Paul Mailloux
Cad/Cam Applications Engineer
NyproMold Inc
144 Pleasant Street
Clinton MA 01510
Phone: (978) 368 - 4598
Fax: (978) 365 - 4548
www.NyproMold.com ____________________________________________________________________________________________________...
You might want to check your license file to see what the file is
"keyed" to. I don't have the FlexLM manuals in front of me (to check
the -97,121 codes), but from what I have seen elsewhere, the license
file might be keyed to the old systems disk drive. In the Windows
environment it is possible to do that instead of the more common (under
UNIX anyway) Mac Address. If that is the case, you will need to obtain
a new license file from PTC.
Try running the commands on the new machine to obtain the LMHOST
information and compare that to the information in the current license
file. Hopefully that will reveal something useful.
--Jim Augeri
MCAD Tool Support - Engineering Quality and Tools (EQT)
Honeywell Aerospace
9201 San Mateo Blvd. (MS B-3)
Albuquerque, NM 87113
Phone - 505.828.5808
Fax - 505.828.5500
james.a.augeri@honeywell.com
This e-mail message and any attachments are for the use of the intended
recipient(s) and may be controlled by U.S. export control laws. Any
unauthorized review, use, disclosure or distribution of this
communication in whole or in part without the express written consent of
Honeywell, or the U.S. Government as required, is prohibited. If you are
not the intended recipient(s), please contact the sender by reply e-mail
and destroy the original message and any copies of the message as well
as any attachment(s) to the original message.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
