We have discovered that the line font for centerlines (axes) are plotted larger on paper than as they appear in the drawing (on screen). Apparently, this problem has been around for quite some time, but was not reported until today.
We estimate that they plot approximately 4 times larger. For example, the short dash is .125" on screen, yet is plotted .5" on paper. I've tried the config option "use_software_linefonts yes" and also disabling pen tables, but this did not help.
We use only the default (built-in) line fonts/styles. Our plotter is an Oce 9400 (HPGL2). I tried some other output formats, (such as tiff) but they do the same thing.
Any advice?
Gerry Champoux Williams International Lead Engineer 2280 E. West Maple Road Information Technology Walled Lake, MI 48390 (248) 624-5200, x2816 (248) 960-2607 (fax) - http://www.williams-int.com Pro/E WildFire 3 M050 Intralink 3.4, M030
This email message and any attachment(s) are for the sole use of the intended recipient(s) and may contain proprietary and/or confidential information which may be privileged or otherwise protected from disclosure.
Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient(s), please contact the sender by reply email and destroy the original message and any copies of the message as well as any attachment(s) to the original message.
