Manual Uninstall
ptc-2597541
Manual Uninstall
Ok, here's the description of my problem: (This was two months ago or so, my memory is a bit shaky here) Used to run 3.0, then the school upgraded to 4.0(M030). I uninstalled 3.0 and then went ahead with the install of 4.0. Everything went fine, I thought, except that I got a huge warning of the script files that didn't install. Ok... then I tried to run ProE and it worked fine. Recently, I had to use Mechanica to run an analysis, but it wasn't there. Went back to the install, checked all the ProE components were checked. Then, I noticed that the install directory was also the setup directory. Ok, then I went to uninstall it, except it didn't show up in my software list. Tried to install on top of it to see if it would add in my add/remove program list. No luck. Deleted all the registry keys that have to do with PTC and ProE. Setup still thinks I have ProE installed. Deleted setup/installation folder. Unzipped to a new setup folder. Still no change. Any solution?
Even if it detects the a version that you don't have, a box should pop up asking "PTC.Setup has determined that you are configuring and existing installation, would you like to recopy all files from the CD?" If you click yes, it should reinstall over what ever you have left.
