Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We are on WF3 M210. There use to be a way to merge 2 parts in assembly and then just have the 2nd part have all the info that 1st part had plus it would be updated every time it was modified in pre-WF days. Does anyone know how to do this in WF?
I looked at the menu mapper and I can't find the old command as well it was under advanced utilities and then the command was merge.
This is the steps I had taken to do this:
1. Create part to merge in interlink not from pro-e itself. 2. Create a new assembly in pro-e, name it whatever default is fine. 3. Component > Assemble > then chose the new part that is empty. 4. Constrain by Cord Sys or if not Cord then use align. 5. Component > Assemble > then chose the original part. 6. Constrain by Cord Sys or if not Cord then use align. 7. Model Tree you will see 2 parts if done correctly. 8. Advanced Utilities > Merge 9. Pick on the empty part first then Done, Select 10. Then pick the original Model 11. Keep references and copy datum's > Done 12. Always detach part from assembly. Pick Yes 13. Then delete the assembly
Rick LyBarger Jr.
Husky Corporation
2325 Husky Way
Pacific, Mo 63069
(w)636-825-7221
RLyBarger@husky.com
This electronic mail message contains information that (a) is or may be LEGALLY PRIVILEGED,CONFIDENTIAL,PROPRIETARY IN NATURE, OR OTHERWISE PROTECTED BY LAW FROM DISCLOSURE, and (b)is intended only for the use of the Addressee(s) named herein. If you are not the intended recipient, you are hereby notified that reading, using, copying, or distributing any part of this message is strictly prohibited. If you have received this electronic mail message in error, please contact us immediately at (800) 325-3558 and delete the message completely from your computer system. Thank you
This email has been scanned by the MessageLabs Email Security System. For more information please visit This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
