Merge Command - Where did it go?
mainman
We are on WF3 M210. There use to be a way to merge 2 parts in assembly
and then just have the 2nd part have all the info that 1st part had plus
it would be updated every time it was modified in pre-WF days. Does
anyone know how to do this in WF?
I looked at the menu mapper and I can't find the old command as well it
was under advanced utilities and then the command was merge.
This is the steps I had taken to do this:
1. Create part to merge in interlink not from pro-e itself.
2. Create a new assembly in pro-e, name it whatever default is
fine.
3. Component > Assemble > then chose the new part that is empty.
4. Constrain by Cord Sys or if not Cord then use align.
5. Component > Assemble > then chose the original part.
6. Constrain by Cord Sys or if not Cord then use align.
7. Model Tree you will see 2 parts if done correctly.
8. Advanced Utilities > Merge
9. Pick on the empty part first then Done, Select
10. Then pick the original Model
11. Keep references and copy datum's > Done
12. Always detach part from assembly. Pick Yes
13. Then delete the assembly
Rick LyBarger Jr.
Husky Corporation
2325 Husky Way
Pacific, Mo 63069
(w)636-825-7221
RLyBarger@husky.com
This electronic mail message contains information that (a) is or may be LEGALLY PRIVILEGED,CONFIDENTIAL,PROPRIETARY IN NATURE, OR OTHERWISE PROTECTED BY LAW FROM DISCLOSURE, and (b)is intended only for the use of the Addressee(s) named herein. If you are not the intended recipient, you are hereby notified that reading, using, copying, or distributing any part of this message is strictly prohibited. If you have received this electronic mail message in error, please contact us immediately at (800) 325-3558 and delete the message completely from your computer system. Thank you
This email has been scanned by the MessageLabs Email Security System.
For more information please visit
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
