Part Conversion
wolfymik
Part Conversion
I am new to this list and apologize if this has been covered before, but
I am running into the following issue. I am unable to create a
conversion with an edge rip along a specified edge. We
have had similar issues with other parts where we were able to select
the edge to rip and the conversion goes through properly, but when we go
create the flat pattern it errors out. It seems as if it is not able to
properly create the corner relief.
I am unable to send the model through the user list since they have a
message size limit, so please contact me and I will forward the model to
you. Below is the best I can do at creating a representation of what
the model looks like.
_____/ \
/_____\ /|
|_____ | /
Any assistance with this issue would be appreciated.
Thank you,
Michael Wolf
The information contained in this communication may be CONFIDENTIAL and is intended only for the use of the recipient(s) named above. If you are not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please notify the sender and delete/destroy the original message and any copy of it from your computer or paper files.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
