TK'ers,
I want to use the function ProDwgtableRetrieve, but how do I tell it what sheet to put the table on? I want it on sheet 2. I am in planning stages do not want to write sample code at this time. Thanks for any help.
TK WIZARD function Description
Retrieves a stored Pro/Engineer drawing table and places it in the specified drawing. This function is the same as the Pro/Engineer command sequence Table, Save/Retrieve, Retrieve. it enables you to add a table to a drawing without having to specify all the table properties in your programs.
Synopsis
#include <prodwgtable.h>
ProError ProDwgtableRetrieve (
ProDrawing drawing
/* (In)
the drawing into which to retrieve the table.
ProName file_name
/* (In)
name, excluding the extension.
ProPath file_path
/* (In)
path to the table file, relative to the working directory. file_version- table file version (0 = the latest).
int file_version
/* (Unknown)
ProPoint3d position
/* (In)
the position of the upper left corner of the table on the drawing sheet. This argument is in screen coordinates.
ProSolid solid
/* (In)
The solid model from which to copy data into the table. If NULL, the table will be created with no data.
ProSimprep *simp_rep
/* (In)
The simplified representation (of solid) from which to copy data into the table. If this is NULL and solid is not NULL, all the model data will be copied into the table.
ProDwgtable *table
/* (Out)
failure.
Returns
None
Do I call ProDrawingCurrentSheetSet before calling retrieve?
