Problem using search function (CTRL+F)
ptc-1966601
Hello, Are there anyone else experiencing a buggy search function using the command CTRL+F in WF3? When I want to search for a specific datum plane in a part or assembly, the search funtion finds it and I select it. When I press "Close" to confirm my choice the program loses my selection and I have to repeat the search procedure. Sometimes I have to repeat 4-5 times before Pro/E accepts my selection. This is very annoying when I want to assemble parts or assemblies. I'm using WF3 M130 on a XP 64-bit machine. If you have a workaround or an explanation it's very much appreciated. Regards, Hy Nguyen.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
