RE: Unbelievable - Assembly WILL NOT SAVE. Possible Rantincluded.
rmaillet
The answer or summary- spend lots of time reading the Intralink warning
dialog boxes, look for offending Generics/Instances, and Retrieve
Instances in the WS. Let the items get modified then update in the WS.
A File-Replace can also be done after retrieving instances, but then you
un-do your work that you are trying to save.
Not the end of the world if Intralink had the back-bone [front-bone] to
be able to support 1000s of objects in the Workspace, b/c then I'd just
include all instances to avoid the problem. A clear example of why a
Relationional database is superior to a I/O File Database. The local.ddb
file must be processed and sorted/searched/updated for simple
operations? i.e. Why not a local.ddb [or table] for each workspace? I
can see Intralink now, wanting to delete or add a record to the
local.ddb. Read in the complete File, Erase a few lines at the end of
the file, and re-write the entire file back to Disk. Perhaps this is
just done in Memory. Even then, bulky and poor implementation of an
otherwise decent and good product.
Thanks for the help - Robert Maillet
QuestAir Technologies
Robert a simple solution wee use is to set up a rule based simplified
rep that excludes all our our lib parts. When a user hits the not able
to save dialog. They switch to the simp rep called no hardware....
erase not displayed... switch back to the master and bingo you can now
save.
Brian
H A R R I S C O R P O R A T I O N
Government Communications
Systems Division
HARRIS
Post Office Box 37
Mail Stop 22 2112
Melbourne FL USA
32902-0037
Brian L. Taylor Phone: (321)
727-5742
Designer III Fax:
(321) 727-4124
E-mail: -
assuredcommunications(tm) www.harris.com
<http: www.harris.com="/>
This information is only intended for the use of the individual or
entity named in this email. If you are not the intended recipient, you
are hereby notified that any disclosure, copying, distribution, or use
of the contents of this information is strictly prohibited. If you have
received this email in error, please notify me and delete it
immediately.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
